1 - 10 of 10 Posts
Scuba
· Banned
The dealer reflashed my ECU and messed up my APR chip (i know its supposed to be encrypted but it somehow converted it back to stock). So i got the V2 (had the V1 before) and im peaking at 12psi in all gears........is this wat V.2 is like?
before my peaks for each gear were as follows:
1st = 13psi
2nd-4th = 14-14.5 psi
5th = 16-17psi
It still feels alot faster, but ive been running a messed up chip for about 3weeks so i lost the feel if it is like it was before or not.
Discussion starter · #3 ·
Re: (spoolinvdub)
Quote, originally posted by spoolinvdub »
reset your ecu and make sure you go back in to your chip mode
I just did that 30minutes ago.....wat you mean back to my chip mode? (i only have one program if thats what you are reffering to)
Discussion starter · #4 ·
Re: (Scuba)
EDIT:
just read the reseting your ECU is not the same thing as refreshing a new program onto it.
not to sure how its done.....but i have a general idea. If someone may give me some more details on how to reset my ECU i would appreciate it.
be back in 10minutes......pissed or happy.....we`ll see
Re: (Wolf1.8)
Quote, originally posted by Wolf1.8 »
you will see a decrease in boost with v2...I lost about 3-5 psi at my spike, but it still seems stronger throughout the rpms!!
Hefty drop compared to what others are seeing. I'm seeing 22 PSI spikes on V2, so if this was the case I'm sure my K03 Sport would have crapped out by now on 25+ PSI spikes.
Stronger = timing
Discussion starter · #9 ·
Re: (Raman Gain)
Quote, originally posted by Raman Gain »
Stronger = timing
im guessing your running an MBC or a N75 then
Re: (Wolf1.8)
just to clarify...I spike at ~17-18 now whereas I was spiking at ~21-22 on the previous version
1 - 10 of 10 Posts
