In '06 I purchased a new GTI. One minor issue I had was a steering wheel that was turned slightly to the left when going straight. I pointed it out and the dealer straightened it. A few weeks ago I purchased a CPO '16 Passat. During the test drive I noticed that the steering wheel had to be turned slightly to the left when going straight. I pointed it out and they agreed to fix it. After getting the car back the issue remained, but this time the wheel had to be turned slightly to the right when going straight. I pointed this out to them and they told me to bring it back.
After the second service visit, they claim the alignment is all correct and that the steering wheel issue I'm noticing is due to crowning of the road and other imperfections. So I go pick up my car and go on a test drive with the service adviser. We find a road that we both agreed was nice and flat and I can clearly see that the steering wheel is off-center, this time it's back to its original state in which I have to turn it slightly to the left to go straight. Adviser claims there's not much else they can do and that the tech said if he made any more adjustments it would throw the alignment off. I stated to the adviser that I was not satisfied with the results, but I also did not want to leave my car with them again.
I had a chance to drive two different loaners, a GTI and a base Jetta. Both had the same steering wheel issues. What is the deal here? Is this normal? My Passat tracks straight, but it's so annoying to see the steering wheel not straight. Will another dealer have better luck fixing this for me?
