Re: anyone hear about a b4 recall (jbrams)
Here's what a "service bulletin" search pulled up:
Make : volkswagen
Model : passat
Year : 1995
Service bulletin num : 0101
Date of bulletin: jun 12, 2001
Nhtsa item number: 621613
Component: seats
Summary: subject regarding latch system lower anchors and tethers for children, installing / retrofitting. *tt
Service bulletin num : 9806
Date of bulletin: aug 07, 1998
Nhtsa item number: 603351
Component: power train:automatic transmission
Summary: subject on automatic transmission fluid ( atf ), checking 01 transmission. *yc
Service bulletin num : 9804
Date of bulletin: jun 22, 1998
Nhtsa item number: 601872
Component: other
Summary: subject on maintenance intervals. *yc
Service bulletin num : 9811
Date of bulletin: aug 24, 1997
Nhtsa item number: 603353
Component: electrical system
Summary: subject on additional obd ii diagnostic trouble codes ( dtcs ). *yc
Service bulletin num : 15 9701
Date of bulletin: jun 04, 1997
Nhtsa item number: 53616
Component: engine and engine cooling:engine:gasoline:belts and associated pulleys
Summary: toothed belt runs towards outside, wears out/ jumps off, and cracks. *ak
Service bulletin num : 9704169710f
Date of bulletin: apr 16, 1997
Nhtsa item number: 53610
Summary: subject on the automatic transmission control module can additionally recognize two diagnostic trouble codes (dtc) not currently shown in the repair manual. *yc
Service bulletin num : 9704109707d
Date of bulletin: apr 10, 1997
Nhtsa item number: 53604
Summary: conditions with engine intermittently will not start. *yc
Service bulletin num : vw90/9501
Date of bulletin: feb 01, 1995
Nhtsa item number: 42009
Component: electrical system:wiring:interior/under dash
Summary: revised instrument cluster due to loss of memory in the multi function indicator (mfi). *tw
Service bulletin num : vw87/9501
Nhtsa item number: 42010
Component: equipment:electrical: air conditioner
Summary: r-134a expansion valve noisy. *tw
