1 - 11 of 11 Posts
Cubix
I've had this problem since the begining of the summer.
While driving the speedometer needle stays at 0 MPH, and ocassionally jumps up and shows my speed, sometimes it will stay on, sometimes not. When I tap it sometimes it will come on as well. Also my fuel gauge shows the fuel in real time, not as an average like it should
ex.
I drive up hill, the gauge lowers, I stop fast it raises, making turns also affects it.
I'm wondering if anyone else has had a similar problem or could give me advice, thanks..
BTW, I did check the harness in the back and even cleaned it.
Re: Gauge cluster problem (Cubix)
I JUST FIXED THIS PROBLEM WITH MY COMPUTER TOOL (A BIG HAMMER)
..... THERE IS NO WAY TO FIX THIS PROBLEM OTHER THAN REPLACING IT. $50 IS WHAT I PAID FOR MINE, NOW THE GAUGE READS ONLY 56K INSTEAD OF 103K
Discussion starter · #11 ·
Re: Gauge cluster problem (Dave@S3Designs.com)
when you say soilder the harness points, do you mean the connections on the pcd for the harness?
Alright I used my obdtool only to find that no speed signal is being sent and i get error code 16885 - Vehicle Speed Sensor Range/Performance
Modified by Cubix at 10:40 PM 7-23-2004
1 - 11 of 11 Posts
