Re: Rigging a switch to radiator FAN (fastslc)
Yes.
With a caveat: You *must* put diodes inline at terminal 1 of the radiator cooling fan thermo switch and also inline at terminal 3 of the a/c pressure switch. Make sure you install the diodes properly biased so that current will not flow back through either of those circuits.
Use 12VDC, not ground, as you can tell that 12VDC is expected by the fan control unit. If you use ground, fuse #19 will (or at least should) open.
You may even want to expand your idea and use a double pole double throw (DPDT) toggle. You would connect the other pole on the switch to terminal 2 of the radiator cooling fan thermo switch. Use an inline diode here too. This will give you the ability to select either high speed or low speed fan as conditions warrant.
As much as I can recall, this is exactly how mine is setup. I chose to connect my wires at the fan control unit so I could wrap everything up in the stock harness and make it look factory. Don't forget the diodes though!
Good luck! Let me know how it turns out.
Don
