Re: (-DOOMED-)
I bet your tires aren't 205/40/17's. If they are....you probably have the wrong offset. Offset the measurement of where the mating surface of the wheel is in relation to the lip.
Think about it...if you had a 17x7" wheel that bolted to your car in line with the inner lip or in line with the outer lip you'd have verrrrry different fitment problems, so you need to know more than just the diameter and width of your wheels, they'res more to it.
Get more info (write down all the #'s printed on the inside of the wheels and report back) and find out what size tires are on them there things.
