ok, if someone could just let me know which bolts i need to remove the front bumpter. I know it should be the same as my corrado (which i've removed before) but just to clarify. On each side theres a row of 3 bolts, i remove the two OUTER bolts, correct? I've been told i should support the sub frame while i'm doing this ti make sure it doesn't fall.
