hey guys whats the correct tire size to use on 19 inch wheels to keep the odometer readings correct and to maintain the stock overall diameter of the wheel? TIA
Quote, originally posted by veedubpwr » |
hey guys whats the correct tire size to use on 19 inch wheels to keep the odometer readings correct and to maintain the stock overall diameter of the wheel? TIA |
Quote, originally posted by RavinJetta » |
I am running 235/35/19 up front and back and it fits real well. No rubbing up front on a 8.5" rim with a 25mm offset. |
hmmmmmmm........thats strange......i got my eye on a set of 19s that come with 235/35/19 offset 35 now im worried i will rub. But then Ravin said he has no problems but you do. Im
Quote, originally posted by ACEdubs » |
I don't understand this?? I'm running 19x8.5 CH's with an offset of et30. I rub like crazy on the edge of the fender liner. Almost right where it meets the fender. Its only the tire that hits, but its a really annoying sound. I am pretty LOW though.... edit: I ONLY RUB UP FRONT ![]() Modified by ACEdubs at 2:09 PM 2-22-2005 |
you won't rub with et35. If mine were et35 I wouldn't be rubbing. Its "just" rubbing by like 2mm.... |
How much are you dropped? I am dropped about 1.6" or so. |
