has anyone else experience fuel pump dying @ 35,000. will bad gas cause it to go ? i've been using premium, but a friend says i do not have to. is that true ? what are others doing ?
thanks
thanks
Quote, originally posted by greg2step » |
is this a common problem w/ the 2.8v6? |
Quote, originally posted by Brett1 » |
... Running low or out of gas wears them fast, as the gas cools and lubricates the motor and pump. ... |
But even with abuse, the typical fuel pump lasts 100,000 miles easy. |
My car started then stalled last night (at home), now it wont start at all. it cranks over fine, but that is it. You guys jinxed me big time, as it sure seems like a fuel pump problem. Thats just crazy to have pump problems under 30,000 miles. I got to dump this pig, first the evap system alarm, then the trans in limp mode, now the car wont even run! Brett 2003 GLX |
...the connectors in the right footwell were badly corroded, along with the trans ecu connections. |
