I heard that you could adjust the blow off valve to increase the pressure on some turbos. Is that possible to do on the 1.9L TDI's?
Quote, originally posted by jigggity » |
I heard that you could adjust the blow off valve to increase the pressure on some turbos. Is that possible to do on the 1.9L TDI's? |
Quote, originally posted by Mike@ForgeMotorsport » |
We have just finished our two-year development of vehicle specific electronically-controlled blow-off valve kits for the VAG group diesel vehicles. They should be available for purchase very soon! ![]() Let me know if you have any more specific questions or concerns! |
Quote, originally posted by TDIRyan » |
if you do get a chip, I'd highly recommend a boost control valve. Your turbo will thank you later. http://www.boostvalve.com |
Quote, originally posted by GoFaster » |
Oh boy ... A blow-off valve of the type used on some gasoline engines has no place on a diesel engine and serves no function from the point of view that I am not concerned with making noise - only power. If someone would care to prove me wrong via independent dynamometer tests, or to loan me such a piece so that I can perform such tests, I am fully prepared to retract the statement made above. (I don't think I'll have to ...) A *mechanical boost controller*, on the other hand, CAN serve an important function but it is an entirely different device from a blow-off valve. I think we'd better end this discussion right here. I recognize the Forge Motorsport name - but I still maintain that a blow-off valve serves no useful function on a diesel ... |
Quote, originally posted by RogueTDI » |
Suffice to say the Forge unit is filling a market demand for "bling" then. |
Quote, originally posted by ULSDin2006 » |
Cool. Anything to make a quick buck from the suckers, right?
