1 - 13 of 13 Posts
Discussion starter · #7 ·
Re: is it broken?? my CEL went off! jk (WOLFPILOT16V)
Quote, originally posted by WOLFPILOT16V »
the bulb prob. blew out
haha, thats a possibility. whats the life of a bulb? i think my CEL has been on for at least 500000000 hours.
Re: (VW-JettaVR6)
Usually when the ECM detects a fault and triggers the CEL it keeps running test to see if the problem corrected itself (i.e. filling up the car with it running can trigger a cel. Massive evap leak) .if after a set number of drive cycles the problem is no longer present then the light shuts off.
Re: is it broken?? my CEL went off! jk (dirk_diggler)
Quote, originally posted by dirk_diggler »
why dont you remove the cluster and take it out... since you probably have a aftermarket steering wheel?
on a 95 its in the lil thing by the headlight switch, very easy to change
but i have an OEM wheel, just need to get it reset http://****************.com/smile/emthup.gif
1 - 13 of 13 Posts
