is it still the donut sized k03 that comes on the 2.0t?
Quote, originally posted by Golf20V » |
I read somewhere that borg warner is still the supplier. From what I remember it's a new version of the K03S. |
Quote, originally posted by Thatguy03 » |
that's what I was understanding, then I heard that kkk and borg warner merged, which may be bad or good, depending on whose prints they are using
Quote, originally posted by syntrix » |
KKK and Schwitzer combined to make borg-warner IIRC. They haven't been the same until they merged. |
Quote, originally posted by VRSICK » |
so, ultumatly, the turbo is still pint size?? http://****************.com/smile/emthdown.gif |
Quote, originally posted by SeaBiskit » |
The vendor for the turbo is KKK. |
Quote, originally posted by osiris » |
It ain't meant to be a 400hp drag machine. |
Quote, originally posted by jprempe » |
variable area turbine nozzles for the win! More vehicles need to come with them IMHO. You can get the best of both worlds that way... |
Quote, originally posted by Pelican18TQA4 » |
VNT turbos aren't used on gas engines because the variable vane mechanisms can't tolerate the high EGTs of gas engines. Of course, Porsche has figured out how to make them reliable enough that the turbos on the new 997TT are VNT turbos (made by KKK, which calls their variable mechnaism "Variable Geometry Turbine"). Dodge had a turbo 4-cylinder that had a VNT turbo on it but it was notoriously unreliable due to turbo failure. |
Borg-warner makes the K series turbos, such as the K03. |
