1 - 17 of 17 Posts
zaberayx
i am thinking on going BT very soon i am thinking on putting a t3super60 together, what is needed for the kit , i know i need the turbo , exhaust mani, 3inchMAF, Software,injectors... what would be the best thing to start with ?
Re: Going BT soon ... (zaberayx)
Quote, originally posted by zaberayx »
faq thread at the top of the forum or search.
I'm doing the same ...
I have everything together though, just need to put it in the car
Should be this weekend or next ... can't wait!
Here's the link to a thread from turbotuner20v, he had an awesome super60 setup.
http://forums.vwvortex.com/zerothread?id=1867365
Good luck w/ everything! If I can later I'll post up everything I've obtained so far for the setup.
Re: Going BT soon ... (lerak2598)
gets rods and standalone, i wish i did that first
feed/return oil / coolant lines
exhaust manifold gasket
turbo to manifold gasket
1.8T oil pan gasket
boost controler: manual or electrcal
A/F gauge is worth getting.
EGT guage
Boost guage
Adjustable fuel pressure regulator
clutch / LSD to get that power down.
downpipe / exhaust system.
Wastegate if its not an internal wastegate.
Blow off valve or Diverter valve.
Rods for more the 350hp (if the super60 even gets that much flow)
well theres a bunch, im half awake so i missed something but thats a start.
good luck.
-ap
Discussion starter · #13 ·
see i used the search buttom , and i still , couldn't find anything i've been on the text for quiet some time and i know the search botton. And i've adviced plenty to do the same, but still couldn't find any good results.
Most open question ever. What do you not know and need answered? Start with that.
Re: Going BT soon ... (technofly7)
Quote, originally posted by technofly7 »
1.8T oil pan gasket
I don't think the 1.8T uses a oilpan gasket ... could be wrong.
I got the 'special' oem spec sealant for the oilpan from ECS ... i've got an aww, do the other engine codes use a gasket?
1 - 17 of 17 Posts
