1 - 8 of 8 Posts
Re: Kinetic stage 1 with FMIC, how do i run 10 PSI? (doobsta)
Small Yellow spring .25 bar (3.6 psi)
Small Red spring .4 bar (5.8 psi)
Small Green spring .5bar (7.5 psi)
Small Blue spring .6 bar (8.7 psi)
Big Yellow spring .7 bar (10.1 psi)
Big Red spring .8 bar (11.6 psi)
Big Green spring .9 bar (13 psi)
Big Blue spring 1 bar (14.5 psi
Hope that helps
Modified by MKII16v at 7:53 PM 6-15-2006
What comression are you running? Stock I think the MKIII(10.0:1 compression) VR6 can run a max of 10-12psi safely before things go pop. Did you get the Kinetics spacer or lower via other means?
Re: Kinetic stage 1 with FMIC, how do i run 10 PSI? (DrunkenMunkey)
Quote, originally posted by DrunkenMunkey »
Where do the 30lb injectors run out of their effiecincy?
10psi is about it as far as the Stage I fueling goes. It's also about it as far as stock compression goes. The jump to the Stage II fueling is a big one and will require the spacer to lower comp.
1 - 8 of 8 Posts
