Re: fog lights on a canadian C (CageyBee)
quote:[HR][/HR]as for the switch and harness, i still haven't found out where the interior harness plugs into. well, i haven't really looked much, but it would be nice to have some pointers
so thompson, turns out that pesky relay was useless anyway.. c'est la vie
-danny[HR][/HR]
First - the harness hooks up to the rear defroster switch (over on the right side of the steering wheel)... just follow that down to the fuse block... unplug that harness and plug in the US spec harness into the same location... it'll have all the same connectors, plus the one for the fog light switch...
Second - the relay also turns off your foglights when you turn off your headlights... not 100% sure on how it works with the Canadian headlight switch, but with the US headlight switch setup (no dtrl -which I converted to as well), if you don't have the headlight switch turned on so that your parking lights are on, then the fogs don't come on either. It may be that with the Canadian dtrl's, there is always power to the relay.. It's just nice to not need to switch off a second set of lights...
And CB - remind me to kick you in the shin the next time I see you... for all the crap you've given me over that little relay....
