wanting to know what the 10.1 comp 110hp engine came in and what years,were they hyd or solid lifter,and whether the head/intake flow better than the 8.5 comp engines and if my existing 90hp would be a direct swap,just getting in to the vw upgrades?
Quote, originally posted by Mr Black » |
NA-spec GTI's (and your 'Rocco) had the JH motor, 1.8 l, "big valves" (40x33) and 8.5:1 compression. I BELIEVE that swapping in the pistons from a Mk2 GTI motor (don't remember the code) or a Mk2 Digifant motor will provide 10 or 10.5 compression right off the bat, since the JH pistons are dished to lower compression. All Mk1 motors were solid lifter In the Mk2's, there was a 100 or 102 hp CIS-E engine that came in GTI's and Carats. There was then a 100 or 105 hp motor in all Digifant Mk2's, the difference being the dual downpipe/manifold. All Mk2's and 3's are hydro lifter |
Moral of the story....a head swap will do nothing for you, but a piston swap will. That plus a better cam (aftermarket), head porting and an OEM 4-2 exhaust manifold and downpipe (has to be from a Mk1 I believe) will open your engine up. Keep the Mk1 intake manifold, keep your fuel injection as-is and maybe add one or two shims to bump the fuel pressure up if you add the other mods. If you go to higher compression you may want to add a knock box from a CIS-E engine (mk2 8v GTI would be the proper donor I believe), or at the very least run premium gas |
Quote, originally posted by polskipolak » |
hey, Ive got the same engine as the OP and Im also interested in this idea of bringing the compression ratio up. Do you know which pistons are used to make the compression 10-10.5? is there anywhere to find out? |
Quote » |
as far as I know the heads have the same sized combustion chambers as the 8.5s right? Would it be possible to just swap the entire bottom end for a newer mark 2 one? |
Quote » |
But then again if your gonna do that you might as well do a 2L swap right? |
Quote, originally posted by 85silverbullet » |
so my jh head is a better choice than what comes on the gti 10.1 motors |
Quote » |
-also wondering if this pacesetter header 1 3/8 pri 2' collector will flow better than the 4-2 manifold's? |
