1 - 13 of 13 Posts
Edwin T.
So whenever I go pickup my girlfriend I park in front of her house and just leave my car running. When I get our of my car, the driver's door unlocks but the passenger's door stays locked. I'm dumb and I always forget to unlock it for her to get in the other side. She's never complained about it, but i feel like an a$$ always forgetting to unlock both doors. Is it possible with a Vag-com to make it so if I open one door, both doors unlock? Thanks a lot.
I suspect that.....
...if you leave your car running that you'd feel like more of an a$$ if you came back out and the car was gone.....
Methinks you can change the unlocking via the MFD.....but yes, you can deactive door locking......just makes one more door for the bad guys to get in....
Discussion starter · #3 ·
Re: I suspect that..... (cb1111)
I just walk up to her door and walk back to my car. It never leaves my sight and only takes less than a minute. I'd like to keep the autolock feature if possible.
Re: I suspect that..... (Edwin T.)
while vagcom can do some added stuff with the locks/moonroof thingys, the basic adjustments +on/off can be made thru the MFD.
check your manual for details, or simply 'experiment'...not very intuitive that way tho'.
Re: Is this possible with Vag-com? (Edwin T.)
Quote, originally posted by Edwin T. »
How about you go over to the pass. side of the car and open the door for her?
Discussion starter · #9 ·
Re: Is this possible with Vag-com? (Rodknock)
Maybe I should just dumb her so that I have more $$$ for mods
Thank you for for your input, I was more curious about the power of Vag-com than really needing to do this. Thanks.
Modified by Edwin T. at 3:59 PM 3-21-2007
Re: Is this possible with Vag-com? (rev18gti)
Quote, originally posted by rev18gti »
this is what i would do...but then i'd get there and look like a doof because the door would be locked.
1 - 13 of 13 Posts
