1 - 20 of 24 Posts
Mr.Incognito
Im working on new suspension and the lower mounting bolts in the rear are really tight so I was thinking about renting an impact wrench. Anyone know where I can rent one? or have any other ideas on how to get these bolts out
Re: (kyle_b)
im all about convience.
i went and bought a compressor and impact gun
did ya spray it down w/ PB Blaster or something similar first?
those bolts can be a real bitch to get loose
Re: (Mr.Incognito)
screw wd40.
go get pb blaster.
night and day difference in removing rusted/stuck hardware.
you can put the jack stands under the rear of the subframe, like under the steering rack where it bolts up to the bottom of the car.
Re: (Mr.Incognito)
dont need a braker bar, just use a hammer to hit the wrench, and make sure you've taken the top parts off first so the rear beam comes down, make sure you have a jack there to catch it so it wont just drop down(wont hurt anything just not fun) and you should be able to get the bolts off. and make sure to use some elbow grease.
Re: (cstjetta)
whatttt? ok start with the basics. (dont take this as insulting it happens alot)
righty tighty, left lossey.
PB blaster.
Torque is the cross product of r X F. maximum torue at 90 degrees.
and if thats your wrench, get craftsman. if that is craftsman, replace. if it does it again, woops.
1 - 20 of 24 Posts
