Re: Greddy FMIC Q (01MomoGTI)
A larger intercooler is not going to give you more hp/tq. It WILL however allow you to not lose power do to heat. I love my 31v. There is a small pressure drop and as stated above, it makes the car feel a tiny bit laggier (is that even a word? lol). The point again is to not lose power when it is hot out or when you do pull after pull after pull...
by the way, a 31v will be what you want unless you are going with a huge turbo.
and yes, it will require som TLC to get it to fit just right. Cutting the rebar sucks, but I feel better with my slightly cut rebar than I would with the little piece of pipe that eurojet gives you.
oh, and if you have an aftermarket bumper or valence, you can mount it upside down and not have to cut the rebar at all. The 20thAE/337 will fit that way. Do some searching man, you will find tons of info that way and may find that gReddy is not for you after all.. http://****************.com/smile/emthup.gif
Modified by 18Tdesign at 12:31 PM 11-3-2007
