1 - 20 of 23 Posts
Re: All the VR6 FI (theflygtiguy)
I had my autotech's in before i put the turbo in. they were great up top and were a big difference before and after in NA form. I put the turbo in and I ran with some guys that have turbo VR's that didn't have cams and we would run. I ran right next to somebody who had about 2psi more than me but I have the cams and a 3" exhaust.
Re: All the VR6 FI (CDJetta)
I have Piper 264' cams
Re: All the VR6 FI (18T_BT)
Quote, originally posted by 18T_BT »
What kind of power are you guys making, what increases have you seen over stock cams. Did you install them after FI or did you use them since they already were on the car?
ran about 10psi on stock cams and then screwed up the tranny. put the 256s in when fixing everything back up and noticed a good difference comparitively
Re: All the VR6 FI (C2Motorsports)
Quote, originally posted by C2Motorsports »
264/268's on my MKII VR6 Turbo
C2Motorsports
Chris do you mean 268/264? I've never heard of anyone running a larger profile on the exhaust side as apposed to the intake side. What type of power results does this yield?
I'm running drcamsharts 264/260 cam.
Was hoping to rev to 8K...how much do you VRT guys rev to with your set ups?
power stops climbing around 5200
Re: All the VR6 FI (DaBeeterEater)
Mine goes to about 6800 or so. I have a video up on youtube that shows a quick run from 2nd through the top of 5th. Look up the user Fohaley on youtube.
1 - 20 of 23 Posts
