1 - 20 of 25 Posts
Gumby17
Hey guys:
I get about 300 miles city driving when I use 92 Octane fuel here in Ohio (using 3/4 of the 14.5 Gallon tank)
I get only about 185-200 when I use 87 Octane fuel.
Do you guys get considerably more, and what should I check to see if there is a problem ?
Joe
Re: Gas Mileage (Gumby17)
i used premium(92) the time before my last fillup and got about 375 miles on the total tank (i calculated to count the red line)
but my last fill up i just used reg. (87) and barely got 300...
if you have a chip you should be using whatever the manufacturer tells you to use. If you have the stock computer then use the recommended octane in the manual. I think VW is 87. It is made to run off lower octane so higher octane does nothing, also your gas mileage shouldn't change that much with stock chip, that's very odd.
Discussion starter · #9 ·
Re: Gas Mileage (Jimmy Bionic)
Well my manual recommends 93 octane but for some reason 92 seems to last longer.
My gas mileage phucked up once I removed the airbox. Maybe the stupid cone filter has something to do with it
I just hope it didn't damage the way the MAF sensor works or any other component
Joe
I regularly get 400 miles to a tank in my '95 2.0 using 91 octane. I always thought it was kind of weird... not that I'm complaining.
My car has an Autotech chip and Techtonics exhaust.. I guess that helps.
Modding saves money!
[Modified by geronimo5206, 5:25 AM 9-14-2002]
Re: Gas Mileage (JonnyBoy-17)
Right now i use the cheapo gas... untill I get my chip
but the way I drive I get about 16mpg.... and my Mom thought i got an economy car
but hey if you drive it just like any other person you will get good millage
Re: Gas Mileage (geronimo5206)
Maybe it's the way I drive. I'm pretty conservative I suppose. I generally don't go more than 10 over the speed limit and I don't accelerate much faster than the cars around me when starting from a dead stop.
[Modified by geronimo5206, 9:36 AM 9-14-2002]
Re: Gas Mileage (Wheel Man)
quote:[HR][/HR]Right now i use the cheapo gas... untill I get my chip
but hey if you drive it just like any other person you will get good millage[HR][/HR]​
I've been getting really vrappy milage too. I have replaced everything I could replace except the cat..... I think I am going to check it out next. If that doesn't work......
Re: Gas Mileage (askibum02)
Why so many miles???
Is that highway driving???
I do a lot of both more city than highway on 93 octane fuel, and I get 250 miles per tank
I changed the O2 sensor and it stayed the same!!!!
May be clean the TB???
1 - 20 of 25 Posts
