Im looking to sell a Neuspeed P-flow chip from a 96 jetta... Perfect working condition when removed, removed when upgraded to a BBM charger... retails for 110$, looking for 75 $hipped obo...
"For VW Golf III & Jetta III 2.0L 8V, 1996-99. 91 octane or higher fuel must be used with this chip. Unleash the power hiding in your factory Engine Control Unit (ECU.) NEUSPEED engineers reprogram your ECU chip to optimize ignition timing under part throttle and full throttle load, and raise the rev-limiter and top speed governor. Horsepower is increased by approximately 11hp at the flywheel. CARB approved (D236-10) when used with a K&N air filter or NEUSPEED P-FLO" http://****************.com/smile/emthup.gif
