Sale Sachs & Clutchnet Clutch kits W/ flywheel From $314.95 Shipped
All Items Include Free Ground Shipping in the lower 48 states
Clutch Masters VW Corrado,Jetta,GTI,Passat 02A, 02J FX100-400 from 379.95 to $459.95 see optiong for your kit
FX100 - Heavy duty pressure plate. Sprung hub steel-backed organic lined disc.
FX250- Heavy duty pressure plate. Sprung hub dual friction Organic/Fiber Tough disc.
FX300- Heavy duty pressure plate. Sprung hub segmented Kevlar disc.
FX350- Heavy duty pressure plate. Sprung hub Fiber Friction lined disc.
FX400- Heavy duty pressure plate. 6-puck ceramic sprung disc.
FX400- Heavy duty pressure plate. Lined ceramic sprung disc.
5 Speed 02J/ 02A Fits Golf Jetta Non Quattro TT
------Full Clutch Kits contain clutch disc, pressure plate, flyweel, flywheel and pressure plate bolts,Release bearing and alignment tool----
1.8T Clutch Kits Starting @ $324.95 (228MM Sachs VR6 Clutch Kit 14 pound Cast Steel Flywheel W/ Starter ring gear Includes 6 flywheel and pressure plate bolts, Alignment tool as shown)
1.8T 1.9 TDI 2.0 Single Mass Clutch W/ Cast Steel 14 LB Flywheel $349.95
1.8T 1.9 TDI 2.0 Single Mass Clutch W/16 LB Cast Steel Flywheel $349.95
1.8T 1.9 TDI 2.0 Single Mass Clutch W/ Cast Steel 22 LB Flywheel $349.95
1.8T Clutch Kits $484.95 (228MM Sachs VR6 Clutch Kit, 11.75 pound Steel Billet Flywheel W/ Starter ring gear Includes 6 flywheel and pressure plate bolts, Alignment tool as shown)
1.8T Single Mass Clutch W/ Steel Billet Flywheel
1.8T Stage 1+ Clutch Kit W/ Flywheel $425 ( Includes 228MM Sachs Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub, ESS 14 lb Flywheel, includes flywheel & pressure plate bolts, Sachs T/O bearing and alignment tool. Rated at 300 TQ at flywheel.
1.8T Single Mass Clutch W/ ESS Cast Steel Flywheel
1.8T Stage 3 Clutch Kit W/ Cast Steel Flywheel $554.95 ( Includes 228MM Clutchnet Red Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub, ESS 14 lb Cast Steel Flywheel, includes flywheel & pressure plate bolts, Sachs T/O bearing and alignment tool. Rated at 445 TQ at flywheel.
1.8T Stage 3 Clutch W/ Cast Steel Flywheel
5 Speed-----Clutch Kits without flywheel contain clutch disc, pressure plates, pressure plate bolts, and alignment tool----
1.8T Stage 3 Clutch Kit $499.99 ( Includes 228MM Clutchnet Red Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub, Sachs T/O bearing and alignment tool. Rated at 445 TQ at flywheel.
02J/02A Single Mass Flywheels
Eurospec Sport Lightweight Flywheel Single Mass Cast Steel Flywheel. 14 pounds with starter ring gear
1.8T Eurospec Sport Single Mass Cast Flywheel $174.95 shipped
Autotech Lightweight Flywheel Single Mass Steel Billet Flywheel. 11.75 pounds with starter ring gear. Comes with Flywheel and pressure plate bolts.
1.8T Autotech Steel Billet Flywheel $310 shipped
-------------Flywheel Install Kits contain Crankshaft Seal with Tool, Main Shaft Seal, Throwout Bearing Guide Tube---------------
1.8T Flywheel Install Kit W/ Flywheel and Clutch disc bolts(FITS MK4 1.8T 5 SPEED ONLY
1.8T FLYWHEEL INSTALL KIT
1.8T Flywheel Install Kit(FITS MK4 1.8T MK1 TT SEE DESCRIPTION) 5 SPEED ONLY
Visa Mastercard Discover and American Express can be accepted via Paypal without registration.
California residents will be charged 7.75 % sales tax.
http://www.FourSeasonTuning.com
The current site only has a fraction of the parts listed that we carry.Please contact us if the items you seek are not on the site.Competitive pricing, Fast shipping, If you see a lower price let us know, chances are we can work with you.
Questions at 714-997-5842
Email is better than IM
sales(AT)fourseasontuning.com*
Thanks for looking.
James
AKA wld101turkey
Thanks for looking.
James
AKA wld101turkey
