I want to help her out and install the new battery for her. Is replacing a battery as simple as it seems? You just take off the negative, take off positive. Take out battery and then put on negative then positive and thats it?
Quote, originally posted by HaterSlayer » |
AHAHAHA ![]() |
Are the chances of good of me going to autozone and picking one up for her Jeep Cherokee? |
Quote, originally posted by DiscoStu » |
If you don't know how to change a battery I would guess you wouldn't want to attempt the alternator. Stick with things like washer fluid and gas. edit: And how did you come to the conclusion that it was the alternator? |
Quote, originally posted by Chris16vRocco » |
An alternator for a Cherokee will be pretty easy to find, although the ones for newer Cherokees are kind of expensive ($130 or so). |
As far as the alternator she had one of her friends go and give the car a jump and it still wouldn't start. |
Well between the sarcasm there is usually good info on here. ![]() ![]() |
Quote, originally posted by Spindle » |
So the 'friends' diagnosed the 'bad alternator' ?? |
Wouldn't the car start with a jump if it was just the battery? |
Quote, originally posted by VegasJetta » |
Sometimes I question the things going on in the world today. Changing the battery ranks among the top 5 EASIEST things to do to your car, its up there with changing oil and putting fuel in... |
