I just put a stock VR6 back in with the Kinetic motorsports turbo kit that originally had on my other engine. there is a Neuspeed ECU in my car should I get re-programed? My air fuel ratio is running high at all ranges from idle to driving, The boost wont hold either at 8lbs. I need to check for vacuume leaks. Is there any way to check for boost leaks with out having to bring it to a dyno?
