I have had a stalling and irregular idol problem for a while now and finally with the help from a friend discovered that when we disconnected the air mass sensor the car idoled smoothly and did not stall after reving. these sensors are not cheap so I was wondering if anybody could give me some advice. Does it mean the air mass sensor is definatly the problem if it runs better by removing it. I know it sounds obvious but im not a mechanic and want to be sure before I replace it, i have already replaced the speed sensor at my mechanics advice and it did not improve anything. Thanks. Scott
