Is there anyway you can use the city light positive and ground wires and turn them into a fog light hook up? to make your city lights run in the foglight position?
Quote, originally posted by pyro2001vr6 » |
Next is the blinker, what I did was I cut up a spare set of H3 projectors from a junked set of headlights and made a blinker assembly apart of it. Its going to be 3 projectors basically in the front, Im excited. ![]() It sticks out the back a little, but it wont interfere with anything and Ill be cutting 2 holes in the back of both headlight covers for the projector and blinker. The projector I am covering with a piece of PVC and the blinker will probably be something plastic+JB weld. ![]() ![]() ![]() its a snug fit ![]() |
wait, so you want your fog light to be your turn signals? with the H3 bulb? any reason you need such good light output blinkers? |
Quote, originally posted by VRtotheSix » |
I want the fog light to be a city light. Is there any other bulb that would fit in there. I cant just switch the wires up, Only one wire goes to the foglight connection. two go to the city light. The set up i am doing is close to yours I have my Lowbeam Projector goes to the lowbeam connection High beam is also a projector and is connected with the high beam Turn signal stays the same. but for the city light i want it to be in the foglight slot. |
So theres no way you can make the bulb fit? or how would i change the wiring? |
Is there anyway to take something that is two wires for a bulb and make it into a single wire power source? |
