1 - 12 of 12 Posts
Chase23
first,my wipers are wiping weird,anyone kno how to fix the motor??
nd second, anyone kno were the fog light switch is for mk3 the gti?...if ther is one, because mine wont come on
thanks..
Re: need help.... (Chase23)
so its the wiper switch at the steering wheel then . feels loose and sloppy? try taking the plastic around that off and see if you can tighten it at the base, or replace the arm itself, and for the fogs thats what i meant is pull the knob towards you
okay on the wiper switch it is layed out like this:
2 up = Fast
1 up= slow
normal position=off
1 down = intermittent
You probably have to push up harder than you are, it will "click" then enter the top 2 positions.
Discussion starter · #8 ·
Re: need help.... (vdubinzhouse)
oo yea thanks they work...
but when i turn the switch to put on my lights, usally the two marker lights stay on along with the blinkers.....but for some reason my passenger side blinker doesnt stay on
it will blink when i flip the left turn signal.....
any ideas?
Quote, originally posted by Chase23 »
any ideas?
Try replacing the bulb first. They use a dual filament bulb for the front blinkers: 1 for the parking lights and the other for the blinker itself.
1 - 12 of 12 Posts
