How exactly is a rear sway detrimental to the proper handling characteristics?
It keeps the car flatter in corners; preventing the suspension from keeping wheel contact in tight cornering and limiting the necessary weight transfer for Haldex to work to its fullest. Obviously it won't completely kill the handling, and in some ways it probably helps, especially if you want to feel more oversteer; but it is causing the car's own parts to fight each other. A Unibrace alone keeps the chassis from flexing too much, allowing the weight transfer but preventing the extra body roll so it does plenty by itself. Again, just my opinion, but if you get the chance you should try it with and without the RSB and see how it does both ways :thumbup:
Do you install or your own parts or pay someone to do it?
I do my own installs
Those stock shocks will definitely wear out more quickly as a result of your lowering springs.
They very well may; but as I said; 55,000 miles now and no detrimental effects yet. I never expect shocks to last more than 60-70K anyway since I push my cars with plenty of "spirited" driving, so if these last longer than 60K then they've gone as long as I expected anyway. Believe me when I say I have no problem with geting some Konis or such; but when these ones work so well there was no point yet.
Thus, if you pay someone to do your upgrades, then you will be paying for double the work as opposed to if you had done springs and shocks at the same time.
Even if you do it yourself, you are wasting your own time by ripping everything apart to only install springs and then ripping it apart again to install shocks...
As I said I do my own installs; and I don't mind wasting an extra 2 hours of my time to save $500 when it wasn't needed yet
I completely understand it is a different story if you need to pay someone else for your installs; that adds quite a bit to any planned effort as far as cost. Seeing as I do my own, I wasn't thinking about that aspect so the "do it once" view point does make more sense in that light.
