-----Engine-----
Intake Air Filter
1JO 129 620 A (Fram replacement - CA8602)
Mass AirFlow sensor (MAF)
06A 906 461 A (for 2.0, but seems to work with AWD)
06A 906 461 D (AWD/AWW)
06A 906 461 L (AWP)
Transverse K04 Turbocharger (upgrade for K03'ers, not the TT225 part)
K04-9500001 (K04 turbo actually the KKK part number, not VW's)
AWD K03 Turbocharger
06A 145 704 A
(Bosch k03-026 cb5015295 5304 101 5066)
AWW K03 Turbocharger
06A 145 704 S
AEB K03 Turbocharger
058 145 703 L
Note about turbos: an "X" at the end of the part number indicates a rebuilt unit.
Transverse Turbo Swap Parts
1J0 253 115 A (Turbo-DP Gasket)
N 907 678 01 Studs (x4)
058 145 791 Washers (x4)
N 013 812 8 Washers (x2)
058 145 757 B Gasket
06A 253 039 E Gasket
N75 Wastegate Regulator Valve
058 906 283 C (AWD/AWW?)
058 906 283 F (AWW/AWP/NB Turbo S)
Diverter Valve
06A 145 710 H (Old)
06A 145 710 N (TT/NB Turbo S)
N249 (Diverter Valve Selenoid)
028 906 283N (NB Turbo S/???)
Audi RS4 Drivers Side Intercooler
078 145 805J
Manifold Absolute Pressure sensor (MAP)
038 906 051
4.0 bar Fuel pressure Regulator
078 133 534 C
Injector Seal O-rings
06A 906 149 (set of 4)
Manifold insert bung
068 133 555 C
Fuel Injectors
06A 906 031 S (AWD, 317.46cc/min@45psi, 369cc/min@60psi)
06A 906 031 AB (APH, 281.78cc/min@45psi)
??? ??? ??? ?? (AMB, 281cc@45psi, 324.84cc@60psi)
TT225 Intake Manifold
06A 133 201 AT
TT225 Intake Manifold Gasket
028 129 748
058 129 717 D
Positive Crankcase Ventilation (PCV) Valve
035 103 245 A
Head Bolts
06A 103 385 A (AWD, APH)
Stock spark plugs
NGK PFR6Q (Bosch F7LTCR, Autolite 9323)
Coilpacks
06B 905 115 E (AWD)
06B 905 115H (AWP)
06B 905 115G (AWW)
Coilpack bolts (early style coilpacks only)
N 101 174 03
Fuel Pump Relay
1J0 906 383 (AWD)
Oil Filter
06A 115 561 B
AWD 5-speed ECU
06A 906 032 CL
AWD Automatic ECU
06A 906 032 CM
AWW 5-speed ECU
06A 906 032 DL
AWW Automatic ECU
06A 906 032 DM
-or-
06A 906 032 GH
AWP 5-speed ECU
06A 906 032 HS
AWP Automatic ECU
06A 906 032 HF
AWP New Beetle Turbo S ECU
1C0 906 032
Lower Pendulum "Dogbone" Mounting Bolts
N 102 683 02 (8x45mm) - you need 2
N 102 466 03 (10x30mm)
N 905 970 03 (10x70mm)
Exhaust Manifold Gasket
058 253 039 G
Stock AWD Downpipe/Cat
1J2 253 058 RX
-or-
1J2 253 058 JX
Front O2 Sensor
06A 906 262 AG (AWD)
06A 905 849 E (New Beetle APH)
Rear O2 sensor (AWD)
06A 906 262 AJ
-----Transmission-----
TT180 Factory Short Shifter
8N0 711 051 (fits AWD/AWW)
8N0 711 051 A (fits AWP)
VW "High-Performance" 75W/90 Transmission Fluid
G 005 100 A1
2nd gear grind fix ... parts off "veedubinla"'s invoice (O2J Transmission):
[2] - G-005-100-A1 - oil, .5 litr
[1] - 00076 - brake klee
[1] - 02J-311-239-J - synchr hub
[2] - 02J-311-247-C - synchr ring
[1] - 02J-311-261-K - 2nd gear
[1] - AMV-188-200-03 - seal comp
[3] - G-005-100-A1 - oil, .5 litr
2nd gear grind fix ... parts off "genxguy"'s invoice (O2M Transmission):
[1] - 02J-311-251-J 1st gear
[1] - 02J-311-261-L 2nd gear
[1] - 02J-311-239-J synchr hub
[2] - 02J-311-247-C synchr rng
[2] - 02J-311-277-A synch ring
[2] - 02J-311-279 Outer ring
[1] - 02A-311-531-K reversgear
[2] - G-005-000 Oil-1 litr
-----Brakes-----
25Y GTI (256mm) rear brake Caliper carriers right: 1J0 615 425 E
25Y GTI (256mm) rear brake Caliper carriers left: 1J0 615 426 E
25Y GTI (256mm) rear brake splash guard shield left: 1J0 615 609
25Y GTI (256mm) rear brake splash guard shield right: 1J0 615 610
Audi TT (256mm) Rotors: 8L0 615 601
Audi TT Caliper left: 8N0 615 423 C
Audi TT Caliper Right: 8No 615 424 C
256mm OEM pads: 4B0 698 451
Wheel hub with bearing: 1J0 501 477 A
-----Body/Interior-----
Touch-up Paint
LST OM2 A7W (Reflex Silver)
LST OP2 Z5N (Nogaro Blue)
Euro 25th Anniversary Smoked Headlights:
1J1 941 017N (Passenger's side)
1J1 941 018N (Driver's side)
US/Canada-Spec. Golf/GTI Headlight Bulbs
H7: Low Beam
H7: High Beam
3457: Turn Signal
W5W or 168: City Light (Parking Light)
H3: Fog
Laminated Glass Windshield for GTI/Golf (Jetta?)
1J0 845 011 L
1J0 845 011 M (with tinted band at top)
337 chin spoiler
1J0 805 903 L 007
Rear Valances
1J5 807 521 C (Jetta 4-Motion, Euro)
1J5 807 521 D (2002.5 Jetta, 4-Motion-style)
1J6 807 521 D (GTI 337)
1J6 807 521 C (GTI VR6 4-Motion)
1J6 807 521 B41 (2002.5 GTI, cut out for dual exhaust)
Golf R32 Body Kit
1J0 807 217H GRU (Front Bumper)
1J6 807 421J GRU (Rear Bumper)
1J0 853 859B GRU (Side Skirt - Left?)
1J0 853 860B GRU (Side Skirt - Right?)
Window Regulator Repair Kit (old-style plastic)
ZVW 269 202 (Driver's side)
ZVW 269 201 (Passenger's side)
Window Regulator Repair Kit (new-style metal)
1JM 898 461 (Driver's side)
1JM 898 462 (Passenger's side)
EuroSwitch
1C0 941 531 A 20H
3 spoke steering wheel
1J0 419 091 AEE74
Radio Delete Panel (DIN panel that matches VW dash material)
1J0 857 231 1QA
Mk4 'Cubby hole'
1J0 857 058 B
Armrest latch "button"
3B0 868 445 Q70 (Beige)
3B0 868 445 B41 (Black)
New Beetle Rear Spoiler Motor
1C0 959 733 C = 48mph up - 10mph down version..
1C0 959 733 B = 95mph up/down version..
Let's make a big list and I'll put it somewhere that VWVortex won't accidentally delete it.
Roger Moore's AWESOME list of Euro parts:
http://bambergvr6.50megs.com/vw_part_numbers.htm
One place to look up part prices:
http://www.vwparts.com/
Interesting pseudo-ETKA (part numbers and diagrams):
http://catalog.exist.ru/audivw/
[Modified by Andy@Ross-Tech.com, 2:57 PM 9-19-2002]
Intake Air Filter
06A 906 461 L (AWP)
06A 145 704 A
06A 145 704 S
058 145 703 L
Diverter Valve
06A 145 710 H (Old)
078 145 805J
038 906 051
078 133 534 C
068 133 555 C
Fuel Injectors
06A 133 201 AT
028 129 748
058 129 717 D
035 103 245 A
Head Bolts
Stock spark plugs
Coilpacks
06B 905 115 E (AWD)
06B 905 115H (AWP)
06B 905 115G (AWW)
N 101 174 03
Fuel Pump Relay
1J0 906 383 (AWD)
Oil Filter
06A 115 561 B
AWD 5-speed ECU
06A 906 032 CL
AWD Automatic ECU
06A 906 032 CM
AWW 5-speed ECU
06A 906 032 DL
AWW Automatic ECU
06A 906 032 DM
-or-
06A 906 032 GH
AWP 5-speed ECU
06A 906 032 HS
AWP Automatic ECU
06A 906 032 HF
1C0 906 032
058 253 039 G
1J2 253 058 RX
-or-
1J2 253 058 JX
Front O2 Sensor
06A 906 262 AJ
G 005 100 A1
-----Brakes-----
Touch-up Paint
H7: Low Beam
H7: High Beam
3457: Turn Signal
H3: Fog
1J0 845 011 L
337 chin spoiler
1J0 805 903 L 007
Rear Valances
Golf R32 Body Kit
EuroSwitch
1C0 941 531 A 20H
1J0 419 091 AEE74
1J0 857 231 1QA
Mk4 'Cubby hole'
1J0 857 058 B
