WHATS LEFT FROM MY PART OUT
A/C Compressor 90.00
Air Bag Passenger 50.00
Air Bag Driver 50.00
Throttle Cable 40.00
DUMP TUBE 25.00
STOCK Cams 40.00
2nd dary Water Injection Pump BOsch USED 25.00
Exhaust Manifolds without gaskets $40 for pair
Steering Column with Key Ignition w. Key 50.00
Transmission Mount 25.00
Transmission BUSHING
Heat Exchanger with hoses 40.00
Stock Injectors only have (5) 15.00 ea
Oil Filter Housing 50.00
NEW OIL RETURN LINE -10an FITTINGS 45.00 TURBO APPLICATION
SWAY BAR END LINKS $15.00
Left Corner Tail SMOKED GLX $25.00 (ONLY 1 LEFT) NOT A PAIR
2.5" Vband FLangnes qty (2) 15.00 ea
Fuse Box $25.00
Plastic Valve Cover 45.00
Upper and Lower Timing Cover(s) METAL ALUMINUM 75.00 for pair
Coolant Expansion Tank $30.00
