1 - 10 of 10 Posts
Woogies
I have a 1991 Golf GL (75k). I noticed the other day that all of a sudden there is a TON of play in my gear shifter. In neutral I can move it up and down 3-4in. There's also 1-2in play when I'm in any gear.
Any ideas what it could be?
Check the linkages up front From the shifter shaft all the way through to the trans) and have a good look in the shifter box. if you can't find a missing / broken linkage or bushing and the ball on your relay shaft is good, then start looking for a new trans.
Discussion starter · #5 ·
I'll check the linkage and stop by my VW dealership and see if they have a diagram of the gear shifter assembly; it'll give me an idea if anything is missing or broken (out of place).
I'll get that 3rd cylinder checked out too ;)
1 - 10 of 10 Posts
