21 - 38 of 38 Posts
that chrome trim is bish to replace. good luck.
get 10mm for the fronts and 20mm for the rear and don't forget longer bolts will be needed.
Fix valance first, then lower it. Don't space the wheels out till you lower it...
^^exactly just make sure you know how to drive so you dont do the same thing as the last guy:facepalm:
I was about to pull the trigger on one that was almost identical (obviously not the same one :laugh:), but went with a cheaper GLS instead. Those are still my favorite looking stock MK4s. Good luck with it.
Discussion starter · #37 ·
Well i guess the random bump i should give a new pic...its not dropped yet but since i got it
2.5" APR Downpipe
3" Euro Catback
Cabonio Intake
Samco TIP
GLI Front Valance replaced
APR Diverter Valve
New South Boost gauge
Software will be next week
Coils in the spring
21 - 38 of 38 Posts
