Hello everyone,
It's my first post here but I've been lurking for a little while now. To be honest my technical knowledge about cars is not that high in regards to problems and repairs. That is why I was compelled to post here.
I scanned my 2003 Jetta 1.8t with ~90k miles on it. It has been having a rough idle and the sound is noticeably louder during idling and acceleration. Also it smells of gas around and inside the car. There is also some sort of leak in the car that causes moisture to come into the car and even cause ice on the inside of the windshield.
I am away from home and my trusted dealer right now, and will be for a while, so I wanted to make sure I know what the problems are so I do not get ripped by the dealer.
Here are the scanned codes.
1. Engine
16795 - P0411 - Secondary Air Injections System (B2)-Incorrect Flow
16684 - P0300 - Random Misfire Detected-Any Cylinder
16685 - P0301 - Cylinder #1-Misfire Detected
17544 (found description online) - P1136 - Fuel Trim: Bank 1 (Add): System too Lean
16687 - P0303 - Cylinder #3-Misfire Detected
16686 - P0302 - Cylinder #2-Misfire Detected
3. SRS
00532 - P1746 - Transmission Control Module Relay-Supply Voltage (B+)
Malfunction Low Battery or Bad Ground
P1750 - Supply Voltage (B+)
Thank You for letting me post my car issue here.
1. Engine
3. SRS
