My fuel gauge has been reading empty for a few months. I've researched the causes online, and tried a variety of things, and I'm still stumpted. Here's what I've tried:
So I really don't know what to do next. #1 seems to rule out the fuel pump sender, unless I misunderstand how it's supposed to work. #3 seems to rule out a cut wire, since there *is* voltage running through that line. I don't know whether it's supposed to be 12v or ~5v. I think the electronics run on 5v but I'm not sure - anyone know?
The instrument cluster I put in temporarily (#4) seems to rule out a bad gauge.
- Bridging the two terminals on the fuel pump connector (that go to the fuel level sender), to try to trick it into thinking that the tank is full. (I bridged A and B in the photo below).
- Measuring the resistance at the fuel level sender terminals. (Between C and D in the photo below, which was infinite).
- Measuring voltage at the fuel level sender terminals, coming from the cluster. (A and B in the photo below; it was 4.59V).
- New instrument cluster (temporary).
- Removing/reinstalling the existing fuel pump (in case the float was stuck).
