If you want to change the PCV lines, you can order the 034 kit. They're a little bit specific to the engine, so pay attention to that. I have one on my track car. Cleaner setup and the hoses will last longer than most off-the-shelf hosing when it comes to dealing with oil.Thanks, but the OP was doing lines, fittings, and resistor kits and I wanted to be lazy and not have to chase all the parts down
034Motorsport 1.8T Breather Hose Kit for 2001-up AWW/AWP Mk4 (Reinforced Silicone)
IMPORTANT Note: There is a Early (2001-2002) or Late (2003+) build split for this kit. The late model cars have an Auxiliary Check Valve Breather Hose that will be eliminated with this kit. The hose can be capped off with a supplied vacuum cap with the kit. In addition the late model kit has a...
034Motorsport Breather Hose Kit | AMU Mk1 Audi TT 1.8T (Reinforced Silicone)
This complete silicone hose kit is designed to replace all of the crumbling plastic and rubber awfulness that is the factory breather hose system on Early Audi TT225 vehicles equipped with the AMU engine code. The 034Motorsport Billet PCV Check Valve is included in this kit! Replaces: Valve...
034Motorsport Breather Hose Kit | AWD|ATC Mk4 1.8T (Reinforced Silicone)
This complete silicone hose kit is designed to replace all of the crumbling plastic and rubber awfulness that is the factory breather hose system. Replaces the following factory parts: Valve Cover Breather Hose - (06A 103 493BD) Valve Cover Breather Hose - (06A 103 221BR) Block to Intake...
