Forum Discussions about this Product
1 - 4 of 4 Posts
    1. · Registered
      Thanks, but the OP was doing lines, fittings, and resistor kits and I wanted to be lazy and not have to chase all the parts down
      If you want to change the PCV lines, you can order the 034 kit. They're a little bit specific to the engine, so pay attention to that. I have one on my track car. Cleaner setup and the hoses will last longer than most off-the-shelf hosing when it comes to dealing with oil.
    1. · Registered
      You might be ok with that but then again i believe that that line is there for a good reason...
      You could...
      1) (cheapest) replace that hose with an AutoZone vacuum hose and that will work just fine or
      2) (best) get the silicone hoses kit and never look back, lets start with the year of your car.
      (99-00) AWD
      http://www.urotuning.com/Breather-Hose-Kit-AWD-ATC-Mk4-1-8T-Reinforced-Si-p/034-101-3005.htm
      (01-04) AWW/AWP/AWP late
      http://www.urotuning.com/Breather-Hose-Kit-Mk4-1-8T-Reinforced-Silicone-p/034_mk4-breather.htm
      anyways up to you :beer:
      **for the SAI check the plastic hoses, sometimes they pop out or crack. make sure they are seated properly.
1 - 4 of 4 Posts
