If you want to save some money we offer the same sway bar links made by whitelineIf you're going for the IDF arms you may as well spring for the adjustable end links:
http://www.usrallyteam.com/index.php?main_page=product_info&cPath=76_208_221&products_id=1151
As for the spindles:
The mk4 20th has axle bolts - so if you grab spindles from a R32, you won't have to change the hubs. The TT used both hub / axle types over the production run.
These hubs are for axles that secure with bolts. Hubs for axles that secure with nuts don't have the inner metal ring.
http://www.urotuning.com/Front-Sway-Bar-Link-Kit-Heavy-Duty-Adjustable-St-p/klc150.htm
These sphercial ones would be a nice upgrade.
http://www.urotuning.com/034-Motorsport-Sway-Bar-End-Link-Set-Mk4-Golf-Je-p/034-402-4000.htm
