Urotuning is proud to offer you 3 different SAI/N249/PCV/EVAP Delete Kits for your 1.8t:
- Basic SAI/N249/PCV/EVAP Delete Kit, 1.8T
- Ultimate SAI/N249/PCV/EVAP Delete Kit, 1.8T
- Silicone Plus SAI/N249/PCV/EVAP Delete Kit with NO Catch Can, 1.8T
- Ultimate Silicone Plus SAI/N249/PCV/EVAP Delete Kit, 1.8T
This will not only clean up your cluttered 1.8t engine bay, but it will also make diagnosing a boost leak much easier. Removing all the emissions from the car streamlines the system, and removes many of the plastic pieces that are common to break over time.
____________________________________________________________________
This is the basic kit that will delete your entire SAI/N249/PCV/EVAP system for any Mk4 Golf/Jetta 1.8T.
Kit includes all the hoses, caps, clamps and resistors to delete the SAI/N249/PCV/EVAP system. (NOTE: The secondary airflow code can only be defeated with software).
** This kit does NOT include the SAI blockoff plate and catch can system. See our Ultimate Kit which includes these items.
UroTuning Recommends the following parts to consider when installing this kit (see parts listings below):
- Replacing the cooling hose flange (it has to come off so why not replace since they are common to fail)
- Using a new intake manifold gasket or upgrading to the NewSouth PowerGasket for added HP
- Switching to a Billet Dipstick Funnel (odds are pretty good you will break the factory orange tube when installing the delete kit)
This is the Ultimate kit that will delete your entire SAI/N249/PCV/EVAP system for any Mk4 Golf/Jetta 1.8T.
NOTE: Be aware installing this kit will cause the Check Engine Light to come, while some codes can be defeated with the resistors the secondary airflow code can only be defeated with software.
** This kit also includes the SAI blockoff plate and a 42 Draft Design Stealth catch can (avilable in Black or Polished). Installation of the catch can is required in a location of your choice.
This is the Ultimate Silicone Plus kit that will delete your entire SAI/N249/PCV/EVAP system for any Mk4 Golf/Jetta 1.8T for customer that already have a Catch Can with 3/4" ports.
KIT INCLUDES:
- Silicone hoses for Catch Can (19mm-3/4")
- Silicone brake booster hose (13mm-1/2")
- Silicone vacuum hose (4mm-5/32")
- Silicone hose reducer for valve cover connection
- 034 SAI Block off plate
- Plug in connector resistors
- All caps, plugs and clamps needed for install
This is the Ultimate Silicone Plus kit that will delete your entire SAI/N249/PCV/EVAP system for any Mk4 Golf/Jetta 1.8T.
By far this is the Ultimate clean install kit available! Catch can is neatly mounted next to the brake booster for a stealth install that looks factory! There is NO drilling required with this kit.
KIT INCLUDES:
- 034 Catch Can Kit with silicone hoses (available in Polished, Gloss Black and Wrinkle Black finish)
- 034 Silicone block breather hose
Click on the Links below to order!
- Basic SAI/N249/PCV/EVAP Delete Kit- starting at $99.99
- Ultimate SAI/N249/PCV/EVAP Delete Kit- starting at $249.99
- Silicone Plus SAI/N249/PCV/EVAP Delete Kit with NO Catch Can, 1.8T - starting at $179.99
- Ultimate Silicone Plus SAI/N249/PCV/EVAP Delete Kit- starting at $369.99
[URL="http://www.urotuning.com/SAI-Delete-Kits-s/3023.htm"
