This stuff is basically a slit pool noodle with double stick at the seam. I put it over the bar assembly that my opener uses to drag the door up/down.I have some foam that I bought from McMaster Carr a couple of years ago to protect my car door when opening and have a little bit left, but it would be difficult to get it to adhere to the hinge areas. One of those pool foam pieces might be the best solution, thanks. How did you fasten it?
https://www.homedepot.com/p/Everbil...PIPHorizontal2_rr-_-204760815-_-204760817-_-N
