1 - 2 of 2 Posts
o1 jetta,less than 2years old but 50k on it.my rear caliper left side stuck and ate through the pads.vw says is out of warranty because of the mileage.what do i do?i am putting new pads and have the rotor cut and also have to change the caliper,the problem that i have is to push back the piston,do i need a special tool for that or what?i've tried to push and twist it back in,nothing seems to happen. any suggestion will be greatly appreciated.thanks""""""""
Re: 01 jetta brake (jet0777)
Yes there is a took for that, it does not just push back it is a screw type. This if for your e-brake.
you can get away with filing down one of those cheap cubes, but something like this would work better.
Or find a place to rent or borrow.
1 - 2 of 2 Posts
