1 - 2 of 2 Posts
01 vr6 gti, 5spd w/95k miles on motor. The good is Motor runs drives good and trans shifts fine, no grinds nor popouts. Car has aftermarket exhaust, performance brake pads, and front nd rear cross-drilled rotors, aftermarket rear bumper spoiler and aftermarket fenders aswell. The bad is small dent on hood and check engine light is on for throttle accelerator sensor (or sumthing like that I forget) I will go and get it checked again to post what axactly it is and the code for it, ASAP.
The following parts have been replaced
mk4 vr6 motor w/ 95,xxxk miles
new coil pack
new mass sensor
new coolant hoses (all of them)
new engine fuel lines
new valve cover gasket
new vac air lines
new crank sensor
new lifters
new timing chain guides
new timing chain tensioners
new headgasket
new water pump
new serpentine belt
new coolant pipe
new thermostat housing
new thermostat housing sensors
new oil pressure sensor
new oil cooler gaskets
new oil filter housing gasket
new voltage reg
new oil cooler hoses
new fuel pressure reg
new sach clutch
new throwout bearing
new fan switch
Asking $4200 or best serious offer. All offers will be considered if reasonable. If interested plz call or text 609-248-6496
1 - 2 of 2 Posts
