Hi,
Last night I rebuilt my valve body in my 2000 Cabrio (I was having a hard 2-3 shift and a 2-second delay from neutral to reverse-no codes stored). I rebuilt my valve body with the Transgo shift kit. I cleaned the valve bores with a Bench Buddy nylon brush set and was very careful to reassemble it the way I took it apart. I changed all solenoids and the wire harness while I had it all apart. Last night during a test drive, it slipped badly for the first 4 or 5 minutes (I could rev it to 3k without moving more than 5mph) then after that it, seemed fine. I though it was because the transmission fluid needed to circulate.
Then this morning, the same thing happened. It takes a few minutes for it to get enough steam to drive. I'm stuck and don't know much about auto transmissions but I am learning. I'd be grateful for any help, thank you!
