If your having delayed upshift cold, and the trans works fine warm, then you probably do need solenoids.. I was excited to find this thread because I'm having the exact same issues, and the solenoid job sounded like the ideal solution, especially because of the relative low cost.
Yes you have a Jatco. Its a Jatco Jf506E and VW calls it a 09A...... because I have a Jatco transmission, not a German one,
They are confused. The trans does not have to come out to replace solenoids. Valve body cover (pan) does have to be removed to access solenoids. They may be confused with the speed sensors. They are inside the trans and trans has to be pulled out and split open to replace the speed sensors. Sounds like they don't know enough about these transmissions.. because they have to pull the whole thing out and split it open to get to the solenoids.
No. Find someone who knows whats going on..All in, they were saying the job would be around $2000. Does this all sound correct?
What a waste of money! Someone who knows whats going on could have checked the range sensor conclusively in 45 seconds with vagcom. Do these guys have vagcom?.They suggested starting with smaller 'fixes' which may or may not solve the problem, so I agreed and we replaced the transmission range switch. $600, no difference.
Fluid service is preventive maintanance and doesn't fix problems. They wasted your money again, plus there is no filter so cost should be cheap. There are no cooler hoses so no "flush machine" can be used, so it should be cheap. Fluid service on 09A is a simple drain and fill, (with a complex fill procedure). They really overcharged you on that one. I Charge 30 bucks plus cost of fluid for drain and fill trans services. (fluid would be 60 to 150 depending on if you wanted dealer fluid or aftermarket)..Then a fluid service. $400, still no difference.
You should be looking for a different shop. Seriously find someone near you who will change the solenoids. Or you can drive to kansas city and I'll do it..So now I'm looking at either a rebuild ($3400), a replacement ($4k+), taking a chance with the solenoid job, or finding a good transmission shop who'll put in a junkyard trans for a decent price.
theoretically it could be a VB problem but since there are dozens of folks in this thread who have fixed this problem with solenoids, and I personally have fixed about a dozen with solenoids (and none with VB work), then sticky solenoids is a known pattern failure.If this is not shifting when cold, you have one of two possibilities. One, you have a solenoid problem. Two, you have a valvebody problem.
@CoolAirVW - Yeah, the trans works great once the car is warm.
This is NOT the case. The solenoid can be replaced without removing the trans, and without splitting the case. It would be a waste of hundreds of dollars to do this.They told me that because the trans would be split open to replace the solenoids,
This would be logical if you had to pull the trans and split the case but you dont, so right now that would be a waste of money.I may as well replace the sensors you're talking about, to save on potential future labor.
You should. Maybe they just need to do a little more research on the matter.After reading your reply, I'm having serious doubts about my guys.
I'm taking the car to another transmission shop tomorrow for a quote.Roy,
Maybe your better off not letting him do the job, did you get a quote from the other guy yet? Does he know transmissions? Gary
