Limp Mode?
So, as I'm sure you've heard a million times over, I am a MKIV owner who ended up with the n92 solenoid shift problem in the 09A transmission--(2002 Jetta GLS 1.8t).
After extensive searching I purchased the full kit from Cobra and took my vehicle to a local transmission shop who said they would do the swap out with my parts and fluid for $250+
-sweet deal I thought.
So I took it up there and they called me a few days later to tell me that the job was done. I go up to the shop to pick up the car and the technician tells me that everything seems to good inside the transmission, the solenoid readouts are on point but the car is throwing a code (I dont recall the code # off of the top of my head, but I remembered looking it up and it had to do with the N88 solenoid) anyway, he says he's not sure what is causing the electrical problem causing the car to go into Limp (safe) mode or the why it's throwing the code because everything inside the transmission is reading as it should and referred me to a local vehicle electrician to do further testing.
The electrician does his thing and comes back to tell me that that the Valve 1 (N88) solenoid is checking in at 6 OHMS when it should be SPEC at 9-24
All other solenoids are in at 16 OHMS and that I have a bad N88 solenoid.
Weird. They're all new and the transmission tech said they all read correctly.
So I take it back up to the transmission guy and tell him whats up. He takes it apart and checks it all out again and says there
isn't a bad solenoid and all readouts are as good as they were before when he sent me to the electrician.
This wasn't a problem prior to the solenoid swap.
I had the cold start issue where I would have to let the engine get to temp before the transmission would change gears, after that it ran smoothly.
So now, what he's thinking we need to do is replace the internal and external wiring harness.
These things are expensive, the only ones I can track down are on cobra transmission and to get them both will be around about $470--and that doesn't even include the Sensor Wire Harness or the sensors.
(Links:
internal- http://cobratransmission.com/09a-vw-internal-wire-harness-803043-1 external- http://cobratransmission.com/09a-vw-external-wire-harness-803042-1 )
So, I was wondering if anyone in this forum had any experience with this.
Is there any place I can find the harness as a set for much cheaper?
could the problem potentially be somewhere else?
Needing help quick. My car is currently taking up space at his shop and we're both wanting to get this problem solved as quickly as possible I'm sure!
Thanks in advance guys!
