02 24v vr6 eurovan
Think the secondary air pump may be bad...
All connections and hoses look intact..
Question about the plugs...I'm getting power from the smaller plug but not getting power from either side of the larger plug connector.....is this right? Or is there an in line fuse that can be bad? Or is the one that I'm getting power from power and the other one just going to the computer or something?
Basically I'm asking should both plugs on the pump have power to them when I unplug them and test them with a good ground..?
Sorry just trying to make sure 100% that it's the pump and not s bad connector or fuse or something silly before replacing the pump and it still not work..
It is throwing a CEL..would it throw a CEL if it was just a fuse or relay..
