Yeah I don't recognize that part either I wasn't able to find it in any parts diagrams but i could have missed itYou may need to give us some more information. What transmission is this out of? Where is this bearing located?
I've had many 020 transmission apart and I have never recalled seeing that type of bearing.
My guess is that it came out of the 5th gear housing, the one that is held in with a torx head screw (part number 32C in the diagram Darepoole posted). I did read that on later boxes those bearings were deleted. If that is the bearing you are referring to, then the output shaft is supported as it goes through the middle housing just on the other side of the fifth gear so I can't image that bearing like an inch later in the 5th gear case is doing much. I think you could get away without it.
Yes, thanks. The bearing is from 5th gear housing, held in with the torx screw. Transmission is from -89 Vw Golf cabriolet.You may need to give us some more information. What transmission is this out of? Where is this bearing located?
