1 - 3 of 3 Posts
In your vid you said you could engage the clutch lifting it by hand? If so thats not good, if you can move the lever past the 9 o'clock postion your looking at possible internal issues like the throw out bearing and or broken finger, or even worse! Check out http://www.brokevw.com has alot of good info on the 020 transmissions
1 - 3 of 3 Posts
