1 - 20 of 53 Posts
i have an 02j that came out of my car, the differential pin came out and did some extenstive damage to the bell housing.
the differential is obviously no good but im hoping someone can use some parts out of it.
the hubs, gears, clutch fork, etc should be usable, so if you need any parts out of it or want the whole tranny let me know!
SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD
Modified by TmoeJ747 at 4:13 PM 11-3-2009
Modified by TmoeJ747 at 3:28 PM 4-10-2010
Re: 02j for parts (TmoeJ747)
any part out of the trans is for sale http://****************.com/smile/emthup.gif
Discussion Starter · #4 ·
lots of interest http://****************.com/smile/emthup.gif make some offers
Discussion Starter · #7 ·
sold the shift lever, shift weight, and cable bracket http://****************.com/smile/emthup.gif
sometimes the ring and pinion doesn't get any damage or chipping from this as usually just small chunks of aluminum get into the gears. this is from my personal observations
Discussion Starter · #10 ·
Re: (austin neuschafer)
Quote, originally posted by austin neuschafer »
i was actually just thinking that today
i was inspecting the ring gear through the hole in the case and it looks fine, the aluminum just mushes through it. thanks for info
so if anyone needs a ring gear, or any of the gears from this trans, they are fine http://****************.com/smile/emthup.gif
however, i can assure everyone that the pinion bearing is junk
(just look at the pics)
Discussion Starter · #12 ·
Re: (carpathianwolf)
Quote, originally posted by carpathianwolf »
are the syncros 1 and 2 gear ok?
yes they are, each gear shifted great before i pulled the trans
there are both thin tooth and thick tooth 1st 2nd synchros, and are not interchangable without changing gears and slider hubs
1 - 20 of 53 Posts
