After some tinkering in the garage, my assumptions with shimming the input shaft inside of the bell-housing won't matter because I forgot about the c-clip holding the BB on the case end - so please disregard my previous statements.
I'm pretty certain the method of using the shims at the BB end is the best way to resolve the back and forth play on the input shaft.:thumbup:
I took some better measurements this morning:
-BB lip to the c-clip is 15.30mm.
-BB seat measured 14.20mm (I had to use a screw and bolt to get this measurement since the calipers were too big)
...I have about 1.1mm of play and looks like I have wear on both sides of the case from the BB lip and the c-clip.
#6 [WHT002050] - Inside of case, sandwiched between BB lip and case (72x84,85x0,65)
#7 [WHT001976] - Outside of case, sandwiched between case and c-clip (72x78,6x0,65)
I might order one #6 and two #7 to play around with different adjustments. Since each shim is .65mm I will need to figure out how to shave off .2mm either from the case or one of the shims.
Also, I played around with a broken 02M case today I had laying around. Tested drilling/tapping a hole for a 6mmx1.00 set screw and it went pretty well. I will have to look into putting a flat spot on an old bearing and see how well it holds.
I didn't have a set screw laying around so I used a 6mmx1.00 bolt.
